Thread: Intex 2500 pump impeller broke!
    Aug 2011
    Cochranville, PA
    228
    Does anyone know of a place to get a new one?
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Re: Intex 2500 pump impeller broke!
    If you have all the broken parts you can try fixing it using two part epoxy.
    The impeller needs to be balanced, so use same amount of epoxy between broken and good fins to keep it balanced.
    Intex does not sell impellers, they prefer to sell you a new filter instead.
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    Aug 2011
    Cochranville, PA
    228
    I figured that. I assume they simply slap a sticker on the pump and sell it. It was sheared off at the shaft. Figured gluing it would simply add weeks the pump. And I was just frustrated with it at this point. But thanks for answering!
