Results 1 to 7 of 7
Thread: 2-speed pump and SWG - wiring questions
    May 2009
    Austin, Texas
    5
    I have a 24' x 12' x 52" AGP with an Aqua Trol SWG and a single-speed pump that needs replacing. I'm ready to order a 2-speed pump (Pentair Dynamo 1 hp) but am uncertain about the circuitry. Do I need to order a separate timer/switch/controller for the 2-speed pump? How do I interface the pump with the Aqua Trol so that the SWG timer is slave to the pump timer? Please advise. Thanks!
    12' x 24' x 4.5' AG oval (8800 gal.)
    Sta-Rite 200 BP Sand Filter
    Hayward 1 1/2 HP Pump
    Aqua-Trol SWG
    38,284
    Re: 2-speed pump and SWG - wiring questions
    You will either need another switch to select high/low or wire in a manual switch to select the speed.
    I do not think your wiring will change much. The hot out of the on/off timer will still supply the SWG and will also just go to the speed switch instead of directly to the pump.
    May 2009
    Austin, Texas
    5
    That seems pretty straightforward. Thank you!
    Aqua-Trol SWG
    22,549
    The easiest thing to do is use the setup you have now and just use a speed selector switch to manually change the speed. If it doesn't come with a speed selector switch (some of them do) let us know and it's easy enough to add one.
    May 2009
    Austin, Texas
    5
    The one I ordered doesn't even come with a cord!
    Aqua-Trol SWG
    May 2009
    Austin, Texas
    5
    I double checked and the (115 V) pump definitely comes without a cord or switch. Is there some standard gauge cord and corresponding switch? Does the switch need to have a ground fault (or something like it) since it will be outdoors?
    Aqua-Trol SWG
    38,284
    the power source to your timer would be the GFCI protection for the pump. And you would wire the pump up with a minimum 14 gauge wire.
    There are threads somewhere with links to manual switches or you could get one of the Intermatic timers to automate speed switches.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
