Results 1 to 9 of 9
Thread: Ph keeps rising
    Jun 2011
    Flower Mound, TX
    37
    Ph keeps rising
    What could cause my Ph to keep climbing? I can't get it to stay down at 7.5 for more than a week. It's getting very frustrating.
    I have a SWG plaster pool, about 26000 gallons, finished in March of this year.
    20' x 40' / 33,000 gallon / IG / Vinyl
    200lb sand filter / 1hp pump
    4hrs full sun with about 45 min part sun before and after
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Ph keeps rising
    Probably the new plaster. I'm not an expert on plaster pools, but if I remember from reading about the issue, new plaster will cause a significant pH rise for almost a year. Lots of MA at the beginning is just part of the process.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Ph keeps rising
    New plaster, high TA fill water, SWG, any water features like spa overflows or slides.
    Jul 2012
    New Jersey
    75
    Re: Ph keeps rising
    Quote Originally Posted by notenuftoys
    Wow, I thought Ph needs to be adjusted on a daily basis, I would have thought with SWG a week is a great result.
    34000 Gallon Salt Water Pool, Jandy AquaPure 1400 SWG, Jandy Del60 Filter, Polaris 380 Cleaner
    Jul 2012
    New Jersey
    75
    Re: Ph keeps rising
    Quote Originally Posted by Richard320
    Richard, you know you look just like my neighbour, the first time I looked at your picture I said what the heck is Brian doing here, he doesnt have a pool.....
    Jul 2012
    Bakersfield, CA
    12
    Re: Ph keeps rising
    You must test once a week and adjust...
    18,000 free form gunite with an inground spa, kreepy krawly vacuum, jandy CL 340 cartridge filter, 2 easy speed pump motor, granite rock waterfall, and starite heater
    Re: Ph keeps rising
    During the first month or so after fresh plaster is applied, you need to test and adjust the PH at least daily, and sometimes more often. Other than that, daily is recommended, but weekly is usually fine.
    I've gone an entire pool season without having to adjust the PH once, though usually I do end up needing to adjust the PH once or twice a year. (I have a SWG.)
    Jul 2011
    Broken Arrow, OK (Tulsa)
    294
    Re: Ph keeps rising
    Our new pool, which was filled with water at the end of January, suffers from the same problem mentioned here, in that the pH keeps rising in it. We have to add about 36oz of muriatic acid roughly every other day to keep it anywhere near 7.4.
    I'm told the acid demand will decrease over the first year...and can already see it just beginning to go down a bit.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Ph keeps rising
    Well, I've had my pool since August 2010 and I continue to add approximately 1 gallon of muriatic acid about every 10 days to keep my pH in check. I do have an SWG and a waterfall that drops about 1 foot and 1 foot wide. Just a part of doing business. I don't think my plaster is still curing. I don't add anything else regularly, so the cost is minimal.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
