Thread: How are my numbers now?
    May 2012
    Austin, TX
    140
    I think I got it under control:
    PH = 7.2
    FC = 8
    CC = 0
    TA = 100
    CYA = 40
    Thanks all for the help!
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: How are my numbers now?
    What's the CH?
    While scale is unlikely with your current pH, it's good to know.
    May 2012
    Austin, TX
    140
    CH is approx 190
    38,548
    With the low pH and the low CH, you are approaching possible issues to your plaster.
    Would recommend bumping up the CH to around 300ppm.
    Check out the CSI (bottom of poolcalculator to see what I am talking about).
    May 2012
    Austin, TX
    140
    Got it - will add Calcium Chloride to the pool. Will stop by the pool store and pick some up.
    Thanks for the help!
    David
