So I have a 24X12 intex I'm currently filling. Did not do a sand base, just hard flat dirt like the instructions said. The issue I'm having is I used concrete pavers under the support legs, and the instructions say to have them flush but the picture just shows it sitting on the ground... I started to dig the first one out to make it flush but the leg barely would stand on it, it kept swinging in towards the pool. I checked the ground with a laser level before starting and the entire area is good +/- 1/2", but with the legs feeling loose I decided to just leave the pavers on top of the ground like in the picture.
Now it's about 1/2 full, and the long sides are bowing in as I've read is normal. I'm just getting nervous about the pads being too high. Even if the outer edge is a bit taller, the concrete edges won't touch the liner like it would if I had a round frame pool...but still I'm worried about putting too much strain on the liner if this is not correct.
Has anyone put this type of pool up without burying the pavers? I could post a few pics later but thought I'd ask to see if anyone has done it this way. Thanks in advance if anyone can help.
