hotlanta said:
Can I add Bleach in my skimmer? If I have chlorinator.. I'm using Aqua Chem 3" Tabs in the chlorinator now
Just pour it in the pool in front of the return stream.
Have you checked your CYA level lately? You know those 3" tablets add stabilizer along wioth the chlorine. It just builds and builds and builds, and the only realistic way to get rid of it is by draining. So be careful....
It would probably be best for you to read pool school and familiarize yourself with the bbb method, it will save you a ton of money and you will take control of your pool.
I started bbb this year and my pool is crystal clear and have only had to shock my pool once at opening
