Results 1 to 7 of 7
Thread: First test results TF100
    8000 gallon above ground, sand filter
    fc4
    ph7.8
    ta210
    ch220
    cya60 (test strips)
    any suggestions? cya measured by strips because my cya test tube was received faulty and leaks
    8000 gal above ground
    sand filter
    30,402
    Re: First test results TF100
    Does TFTestkits know about your CYA view tube?
    This morning was the first time I used the test tube, just recently sent them an email.
    sand filter
    30,402
    New one on the way Monday. Sorry that happened.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by willybill
    fc4
    ph7.8
    ta210
    ch220
    cya60 (test strips)
    You should lower the pH to 7.2. Each time it rises to 7.8, lower it again to 7.2.
    I am assuming you are using bleach/liquid chlorine and that your water is clear.
    Until you can confirm the CYA, I suggest you maintain FC between 5 and 9 and never below 5.
    You're done SLAMing when:
    Thanks for the reply Butterfly, I am using Trichlor pucks for now that came with my pool start up kit, do you recommend liquid chlorine instead? I am also using dry acid that came with the start up kit, is there any risk with using muratic acid instead?
    Thanks to Duraliegh for responding to my cya tube issue so quickly, that is speedy service!
    sand filter
    30,402
    I would stop using the pucks. YOur CYA is (perhaps) somewhere around 60 and that's at the max....pucks will only add more CYA and it is hard to get rid of.
    Dry acid is fine. Muriatic is a bit better but use up what you have.
