Results 1 to 11 of 11
Thread: No drain holes in solar cover?
    Jun 2012
    MA
    347
    I just bought a Solar cover for my bigger pool. The old solar cover had drain holes about every two feet . The new one has none. Should I punch some holes. I wonder why it doesn't have holes?
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: No drain holes in solar cover?
    I remember the first time I ever bought a solar cover. I brought it back to Walmart because it had holes in it!!
    I think it would be better to punch some holes in it. Wait and see what the experts have to say.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I don't really see a need for them. I'd think more water would come from the pool to the top of the cover than would drain.
    Jul 2011
    844
    My thought is that rain water would make the cover sink (with heavy rain) if it doesn't have holes. I could be totally wrong on that but that's what I thought had happened to me on a cover that had apparently not enough holes.
    Bestway SWG
    May 2009
    Pennsylvania
    99
    I have never had one that had holes. If you trim it to fit your pool, the water will just level out . I have never had one sink. I really never thought sinking one was even possible.
    28 foot doughboy AGP, dug out to 5 foot, about 18,000 gallons
    1 1/2 HP pump and 100 lb sand filter
    South Central Pennsylvania
    Jun 2012
    MA
    347
    The one with holes seemed easier to remove but it was also smaller and thinner, and also had less water on the top of the cover.
    Jul 2011
    844
    That's my findings as well. The one with holes had less water on top. I've seen half of my solar cover sunken. Perhaps the bubbles had deteriorated and burst for all I know. But I've definitely had solar blankets sink on more than one occasion.
    GC
    Bestway SWG
    May 2009
    Pennsylvania
    99
    That's why I come here, you learn something every day. Never knew they would sink.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Hm, maybe I should put some holes in mine? It always has water on top...
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    A couple of winters ago we left our solar blanket on when we winterized out pool. It helped keep the winter cover from sinking. Our solar cover does not have holes in it, apparently the water levels out and top continues to float (although we don't use it much).
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    Jun 2008
    NW MO
    185
    I've not had one with holes. I have never had mine sink - even with 4 inches of rain one night. I can see where the holes might let the small amounts of water on top drain out when rolling it up, but it doesn't seem like a big deal to me.
    24ft AGP 52in deep ~13,500 gal
    Hayward Sand Filter 250 lbs
    SWG
    1.5 HP pump
    425 gal stand alone QCA Hot Tub 15-20 yrs old
