Thread: Something is off
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    Something is off
    I can't figure out what is going on. The water in the pool is murky, off color, not the crystal clear blue I am used to. Here are my numbers:
    FC 4
    CC 0
    PH 7.5
    CYA 40
    TA 90
    CH 260
    t 81F
    The only difference is this year I didn't use any borax. Could that be it or is something else going on? Any thoughts would be greatly appreciated.
    free form 40k gal, IG, plaster, Triton II 100C sand filter, Lite 2 heater
    1 1/2 HP Pentair Ultra Flow High Performance pump
    Caretaker in-floor cleaning system
    Re: Something is off
    Murky water is nearly always algae, though once in a long while it happens because the filter isn't working.
    Did you just open the pool, or was the water clear and then turned murky later?
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    The water was clear and then turned dull and murky about a week or so ago. But since my CC is 0, I thought that can't be algae? And the FC holds steady overnight.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    The easiest way to determine if it's algae or filtration is to blast it with chlorine. If it clears up, it was algae. If it doesn't, you're only out a few bucks. If it does, you spared yourself mucking around with the filter.
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    I guess I am worried about mustard algae most of all, that would be a lot of chlorine There was something yellow on one of the walls, but brushed off immediately. OK, I am off to Costco to stock up, just to be safe.
