Thread: How long to wait before shocking after adjusting pH?
    How long should I wait before I shock after adding borax to adjust the pH?
    13x23 ProSeries AG Pool
    SandPro .5Hp Filter System
    AquaPro Pro 500 50k Heat Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,982
    Re: How long to wait before shocking after adjusting pH?
    What happened to your pH? In two previous posts it was 7.5 and 7.8. You don't need borax for that.
    If you're trying for 7.2 or so, you need muriatic acid. If you add that in front of a return while it's running, then brush a little bit, 30 minutes should be plenty of time before you start the shock process.
    I have no idea what happened!! When I checked this evening, my pH was 7.2 and I had 2ppm FC and 1.5 CC. I was going to add borax and then shock.
    Your PH is good enough for now. Leave the PH alone until you are done shocking.
