Results 1 to 10 of 10
Thread: where to put the sock full of CYA?
    May 2009
    Austin, Texas
    77
    It sure seems convenient to tie my sock up after filling it with CYA and drop it in the skimmer basket, but someone in another forum said you shouldn't do that? Is that true? If so, why not?
    Mike
    25k IG w/ Pebble Sheen +8' diameter spa w/spillway w/ Hayward ProLogic +T-CELL-15 SWCG
    Cartridge Filter and Gas Heater on Hayward Pump SPX3215X20Z1PE (w/ 2.00 HP, 1.10 SF motor)
    +separate waterfall on Hayward Pump SPX3210Z1PE (w/ 1.00 HP, 1.25 SF motor)
    Re: where to put the sock full of CYA?
    I have mine hanging at the filter discharge nozzle so that the residue gets mixed by the turbulent water entering the pool.
    Jun 2011
    Long Island, NY
    92
    Ive done the same (hanging in front of the returns) Only did this to not clog up my filter with slow dissolving granules of CYA.
    25K Gallon IG Vinyl Liner w/ concrete walls True "L" 16X32X16, Hayward EcoStar VS pump, Hayward Swimclear C4030 Filter, Hayward 21104T Heat Pro Titanium Heat Pump, Hayward Aqua Plus SWG + Automation, 2 Hayward Color Logic 4.0 LED lights, Polaris 9300 cleaner. TF-100 test kit.
    tjwaggoner's Avatar
    May 2012
    Ashland KY
    88
    I hang my sock in front of a return.
    10,000gal fiberglass kidney
    3/4 hp whisperflo
    Sand dollar SD80
    IC40 SWCG
    (2) PAL2000 multi colored LED lights
    all 2" plumbing
    no water features/no spa
    TF Testkit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    I put mine in pantyhose and put it in the skimmer............and run the pump till it dissolves. Just don't let it sit there without pump running.
    May 2009
    Austin, Texas
    77
    Why can't it "sit there without pump running" if it doesn't all dissolve the first day (without running pump overnight)?
    Mike
    CYA in the skimmer basket is just fine as long as it does not completely block the water flow into the skimmer. This is true even if the pump is not running. However, you should run the pump for 24 hours after adding CYA anyway, so that doesn't usually come up.
    It isn't good to leave trichlor in the skimmer when the pump is going to be off. Trichlor is much more acidic than CYA. Left in the skimmer trichlor will build up very high FC levels and very low PH while the pump is off, which can then damage the equipment when the pump turns on. CYA is not nearly that acidic, and it doesn't affect equipment the way chlorine does, so it is not a problem in that sense.
    Jun 2012
    South Jersey
    5
    I put mine in a sock then put the sock in the puck float that I no longer had a use for.
    20,000 gallon
    above ground
    Sta-rite PLD 50
    D.E.
    60 gpm @ 11psi
    1 hp pump
    30 sq.ft. filter
    TF-100 Test Kit
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    What I normally do if I need cya to rise, is to take a cya level reading, fill 1 plastic cup with CYA, dump the contents of the cup into a sock, tie the sock with both a tie and rubber band, put in skimmer in the morning just after pump starts, wait 3 days, remove sock (all the cya should have disolved), wait ~2 more days and read cya level, if still too low, repeat process until cya is where I want it. I'm not aware of any issues with leaving the sock in the skimmer....just make sure to have a sock that doesn't have any holes and keep in mind that at least for the first few hours - there will be at least a ~0.1 drop in pool pH for my size pool - but if done at the start of the day is normally easily corrected via airation by end of day. I wait for at least 1hr after putting sock in before letting anyone swim - although that is probably more a matter of personal preference. I don't run pump continuously for 24hrs after adding, only ~12hrs which is usually enough given our water temp is ~88 degrees most days and the skimmer gets good water flow.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I just added 4 lbs via an old sock in front of the return. It took less than a day to dissolve. Add the CYA, tie off the top, stick it in front of the jet, put a brick on the top to hold it in place. That's it. If you want to rush it, squeeze the sock every so often.
