Results 1 to 13 of 13
Thread: How to clean floating mats
    May 2012
    Allentown, PA
    219
    So any ideas on the following:
    1. How to clean our floating foam mats?
    2. Anyway to stop goggles from fogging up?
    Once the water is balanced I need to worry about the other stuff
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,111
    Re: How to clean floating mats
    For cleaning I simply bring the pool to shock level and toss all the toys into the water. I'll turn them over a few times and such making sure all sides get soaked with water. Kills any algae that's growing.
    As for goggles. They sell an anti-fog spray for glasses. I myself make my own.
    http://www.ehow.com/how_10042_make-own-anti.html
    Jan 2010
    Randleman,NC
    620
    here to..Just throw everything in the pool&shock.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    You might not like this idea....BUT...............spit in your goggles and rub it around.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by doublewide6
    Well, even tho I haven't used goggles in years and years, spit is what we used.
    Some folks would lick the inside of the goggles if they thought spit was a little too much
    ETA: woody beat me
    You're done SLAMing when:
    May 2012
    Allentown, PA
    219
    I have everything floating in my shocked pool and the suntan lotion and some grayish black stuff does not come off the mats. I have been spitting on my goggles and it works for about 6 laps of swimming. I might try some citrus degreaser stuff on the mats. Maybe a baking soda rub? Any other suggestions.
    Guest
    Have you maybe tried the magic eraser on the mats............they get alot of stuff off...
    Maybe a magic eraser for the mats?
    -edit- too slow..
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    wetchem's Avatar
    May 2012
    Somewhere in the middle of Nebraska
    208
    At the hotel I worked at in college, for both lawn chairs and the floating stuff we had for the customers:
    Spray 409 on the mats fairly heavy.
    Let this sit for few minutes.
    Scrub brush the mats and toys.
    RINSE, RINSE, RINSE.
    All of the suntan oils, lotions, etc came off - the white plastic was always white. We did this like once or twice a week for a deep clean (depending on use) and in-between we'd spray the stuff down with disinfectant from housekeeping (who knows what was in that stuff! I would let it sit for the time on the can and then rinse it off per the instructions!)
    You might also use diluted "Simple Green." It usually worked on the stuff; however, I always felt that it took longer to work and required more scrubbing than the 409.
    -WC
    Intex Ultraframe 14'x3.5-Round (4000ish-gal) AG - Vinyl - Intex 5667EG Sand Filter 1600gph :)
    ( retired: 637R Crtrge 1000gph someday it may have another life as a water fountain... or feet washer! Solar Water Heater? )
    :mrgreen: Click here to Goto Pool School. :scratch: How Much Of What? Click Here - Poolcalculator.com :lookhere: TestKits
    May 2012
    Allentown, PA
    219
    Thanks for the input. I'm going to give it a try and I will let you know what works.
    May 2012
    Allentown, PA
    219
    The tool is choice is the Mr. Clean sponge. It works great on the white area around our steps and on the mats. I tried a degreaser, 409, and some elbow grease it did not work so well. I also tried my pressure washer, it did not work too well and I could only go so hard. I have not tried to defog my goggles, but that is next. Thanks
    If you don't want to spit in your mask, which is what I do, try Cat ****. I use it in my motorcycle helmet, works well. Says it works for water goggles too.
    Oh, and that's cat **** anti-fog, not actual cat ****. Lol, that'd get stinky!
    There's also a gazillion other anti-fog products you can try. Spit is really cheap though.
    Rob B
    Ack! I've been censored! It's parc backwards, not the s word.
    Rob B
