You will likely need a beefier DPST relay to handle the load you are describing. You might check the Grainger website for a proper relay for that load.
The Badujet has it's own controls. Mine is connected directly to a 50 AMP breaker. The system, at least mine, uses a air button that can be at the pool. Mine is at the pool wall. I'm not sure what system you have but the Badujet manual will tell you exactly how to wire it and of course you should use an electrician.
