Thread: Cya and TA
    Jul 2008
    Seacoast, NH
    250
    Cya and TA
    I know adding CYA will lower my pH. Will it also lower TA? The pool calculator doesnt mention effects on TA.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    Re: Cya and TA
    As far as I know, the only way to lower TA is to lower the pH and then let the pH go back up. Then you lower the pH again to lower the TA and let the pH rise again - it's a cycle. My TA is high and that's what I've been doing... I'll lower the pH to @7.2 and then turn the return jet upwards so the water breaks the surface. The aeration raises the pH without raising the TA like a lot of the additives to raise pH will. It's been slow going but it works.
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    30,403
    Re: Cya and TA
    To permanently lower TA, you must include aeration into the equation....in other words, manually accelerate the natural tendency to out-gas CO2 out of the water. So as Ms Coffee suggests, the CYA has virtually no affect.
    Perhaps even more important, do not overestimate just how much effect CYA has on pH. Use the poolcalculator to set up scenarios but you will find that adding normal amounts of CYA to your pool will not have any really drastic affect on your pH.
    Re: Cya and TA
    The net effect of adding CYA is normally a small increase in TA.
