Results 1 to 7 of 7
Thread: TF-100 CYA Mixing bottle
    May 2012
    South Florida
    36
    My label on the mixing bottle got wet and the label has shifted. Now What? What are the measurements used in ml to perform test? We've had so much rain; pool has overfilled almost every day for past month.
    IG ~14,000 Gal
    Pentair clean n clear Cartridge 100g/
    SWG Aquapure 1400
    Hayward XL Cleaner
    Premix Marbletite Freestone series
    1.5Hp 2 speed
    TF-100
    22,537
    Re: TF-100 CYA Mixing bottle
    To fill the view tube all the way to the top requires 28 ml of liquid. So that's 14 ml of pool water and 14 ml of R-0013. I haven't used the mixing bottle in a couple of years. I use the regular vial and just measure equal portions of reagent and R-0013 and use the Speedstir to mix it.
    May 2012
    South Florida
    36
    So, what ever volume it is, it's equal water and reagent?
    Thanks
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    Sep 2009
    Greentown, IN
    914
    That's good info to know as my label came a bit crooked. I don't think I've ever done a true 50/50 mix because of the labels position.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I've been wondering about this. I mix in the bottle, shake it up, wait 30 secs. then shake again. If i wanted to use the speed stir, how many seconds would you mix it? Do you mix, wait 30 secs, mix again?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Speed stir it for 10 seconds, wait 25-30 seconds to read it. It does not need to be super precise. Stick with the set amount for sample size.
    Essential Links:
    22,537
    I just mix it till it feels good and then pour it into the view tube. Never noticed a difference in the reading based on how long I mix it. The SpeedStir does such a good job of mixing it that you don't have a problem with it. It doesn't introduce any air into it either. I don't know that it would matter.
