Thread: Winter pool cover for new inground pool construction
    We have completed a rectangular in ground pool with pebbletec finish. We need to purchase a cover when we winterize the pool. Would appreciate recommendations on best cover. Thanks
    pool products ~ above ground pools
    "The man who is swimming against the stream knows the strength of it." ~ Woodrow T. Wilson
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Re: Winter pool cover for new inground pool construction
    I use the Loop Loc II mesh cover.
    It does what I need it to do, and works well. Actually had a nephew run across it one fall by accident. His feet got a bit wet, but he didn't go in.
    When I have to replace, or if I had to do it again, I might look at the Ultra Loc (made my Loop Loc), which is a hybrid of a solid and mesh cover. Most is solid, with a mesh drain panel do allow water to drain.
    There are plenty of other brands out there, but I have had no experience with them.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Thanks for the recommendation. Will look at the Ultra Loc. Appreciate your recommendation.
