Results 1 to 9 of 9
Thread: lost its sharpness
    Jul 2011
    Terre Haute indiana
    60
    lost its sharpness
    fc 6.5 cc less than .5 ta 150 ph 7.8 cya50
    every things looked good until a big swim party today and then the water turned silghty cloudy. have been workin on the TA And PH. was wondering if this is what caused the cloudy look
    19500 gal, IG, haywood s-200 sand filter & pump, 3/4 horse single speed motor, vinyl liner, tf 100 test kit, installed early 80's, Terre haute,In
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: lost its sharpness
    Probably just the biological load. A little extra chlorine and pump run time would be a good idea to help it clear.
    Jul 2011
    Terre Haute indiana
    60
    i give it a try once i get all the rugrats out. thanks
    Cloudy water during and for perhaps 24 hours after a large swim party is common. Bump the FC level up to the high end of the normal range once everyone is out of the pool.
    Jul 2011
    Terre Haute indiana
    60
    thanks, it already looking better this morning
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    You could also try adding some DE or cellulose fiber (FiberClear, ZeoFiber) to your sand filter. Here is a Pool School article on how to do this: pool-school/add_de_to_a_sand_filter. The application process is the same with either product. As for the dosing amount, follow the Pool School article if using DE. If using cellulose fiber, follow the dosing amount shown on the product label. Either way, check your filter pressure frequently as the improved filtering can send the PSI up faster than what you are accustomed to seeing.
    Putting my $ where my mouth is, I use cellulose fiber as an aid to my sand filter with excellent results.
    30,401
    OP's only issue was the increased bather load. This wasn't persistent chronic cloudiness but simply due to the increased organic load (including just some extra dirt) that lots of swimmers always bring to a pool.
    BBB is about K.I.S.S. Simply elevating the FC levels a bit as JohnT suggested above will almost surely get the pool back to clear without the use of anything else.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    OP's only issue was the increased bather load. This wasn't persistent chronic cloudiness but simply due to the increased organic load (including just some extra dirt) that lots of swimmers always bring to a pool. BBB is about K.I.S.S. Simply elevating the FC levels a bit as JohnT suggested above will almost surely get the pool back to clear without the use of anything else.
    Agree that bumping up the FC is the first line of defense in this case, as previous posts had already indicated. The point of my post was to share a suggestion (DE / cellulose fiber) that has worked well for me that the OP (REBARBEE) could consider in the event that the water is taking longer to get back to the clarity it was before the pool party. If the water clears up to REBARBEE's satisfaction with extra FC and pump run time, then that's good enough.
    BoDarville, adding DE or cellulose as a filter aid, while a great general purpose suggestion, will not have any visible impact in this specific situation. With high bather load the cloudiness comes on quickly and with appropriate FC levels is already gone before most of the water can pass through the filter.
