Results 1 to 8 of 8
Thread: Water test
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Water test
    Here is the latest water test results.
    All of the stab is desolved in the pool now .... 5 #'s of it ...
    FC 4
    CC 5
    CYA 40
    Have not done TA test yet. When should I check that ?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    You can go ahead and test the TA about four hours after adding any chemical which might have changed the TA.
    If CC is really 5 then you are going to need to shock the pool.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Sorry CC and TC were wrong ...
    FC 4
    CC 1
    TC 5
    CYA 40
    I will test TA tonight. What sort of number should I be looking for for a TA test ?
    Les
    Helpful Links:
    The ideal TA level depends on your chlorine source:
    Bleach 70-90
    SWG 60-80
    Trichlor 100-120
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Thanks for the TA numbers. Do I still need to shock the pool? If I do I will need to get more bleach when I go out later this evening ....
    Les
    Helpful Links:
    I think of CC of 1.0 as being marginal. It might go away in a day or two, in which case you are fine. If it doesn't go away then you need to shock the pool. You might also double check your test technique. For the FAS-DPD chlorine test, be sure the water goes completely clear in the FC phase.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    This mornings numbers
    Yesterdays numbers
    FC 4
    CC 1
    TC 5
    CYA 40
    Numbers from test done this morning ..
    Temp 60
    FC 9
    CC .5
    TC 9.5
    TA 70 ( first time tested since liner change)
    CYA 60
    Am I headed in the right direction ?
    Les
    Helpful Links:
    Looking good. CC is down, which is great. Your TA is fine (unless you are using trichlor).
