Results 1 to 19 of 19
Thread: Clean & Clear Plus CCP520 vs SwimClear C5025
    Apr 2012
    Southampton, PA
    44
    Is Pentair Clean and Clear Plus cartridge filter better than Hayward SwimClear?
    32/33?k gallon IGP
    Concrete? white plaster
    pump Pentair WhisperFlo, 1HP
    filter Pentair Clean&Clear Plus Cartridge 520 sq. ft.
    robot Dolphin Deluxe 4
    22,553
    Re: Clean & Clear Plus CCP520 vs SwimClear C5025
    I don't see much difference in either of those two. Looks like even the cartridges are about the same price.
    I'd say go with whichever parts are easier to get for in your area.
    Sep 2007
    Central NJ
    59
    There's probably not much difference in the filtering capability/performance if you look at specs like flow rate.
    I just decided between Pentair and Hayward cartridge filters (the 425sq ft models)-- and chose the Hayward. The reason -- the drain valve location worked better for me. The Pentair's drain valve is under the inlet/outlet ports; the Hayward's is on the opposite side. It seemed to me that access to the drain port on the Hayward would be easier.
    Another point for you to keep in mind -- this year's models of Hayward Swimclear (C5030, I believe) cart filters have the inlet port on the BOTTOM and the outlet port on the TOP. The new filters now have a top-manifold design (internally). This is opposite to previous models. Just something you should know in case it wreaks havoc with your existing plumbing.
    Apr 2012
    Southampton, PA
    44
    I don't know nothing about plumbing and my brain almost melted when I tried to calculate flow rates so I'll just do what the pool tech says... I guess.
    He says our current plumbing is all wrong and he'll redo it.
    Here's what he suggested:
    Clean & Clear Plus CCP520 [520 because I insisted on the biggest filter ]
    WhisperFlo 1HP
    IntelliChlor IC40
    I'm not making any huge mistakes, am I?
    32/33?k gallon IGP
    38,520
    Layout does not look too bad ... just odd to use the flew pipe instead of rigid.
    Might be worth considering a 2-speed pump if you are replacing it (not much more up-front cost).
    Also, what is wrong with your current pump? It is possible to just change the motor/impeller with a 2-speed as well.
    Apr 2012
    Southampton, PA
    44
    Thanks!
    It's old and sometimes sounds like circular saw? I just didn't want it to die in the middle of summer, you know...
    32/33?k gallon IGP
    38,520
    If it is just loud, a new motor should take care of that if the wet end is fine ... although it is always nice to have everything new.
    And that style pump is not NEARLY as old as some we have seen still chugging away ... looks the same as the current Super II.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Yeah, what Jason said.
    That Hayward SuperPump looks pretty good. It's easy to work on and parts are readily available.
    Run the pump motor 'til it fails, if you can tolerate the noise. Then you can unbolt it from the pump, take it to a local pump/electric motor place, and get the motor replaced for around $200. I had to get mine replaced in May - in by 9 out by 4. Easy peasy!
    What's wrong with your filter? It, too, doesn't look very old.
    Please disregard my comments if you've got money burning a hole in your pocket and really want to spend on your pool!
    Cheers!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Apr 2012
    Southampton, PA
    44
    Quote Originally Posted by CUTiger78
    Cheers!
    The filter is broken and not filtering ****... besides, we really dislike handling DE and dumping it on the lawn... my DH likes cleaning things he doesn't mind cleaning Dolphin's diaper and says he'd rather clean cartridges than do this backwashing thing. We are weird
    32/33?k gallon IGP
    Apr 2012
    Southampton, PA
    44
    They want $1,500 for the IntelliChlor... it's, like, 2 times cheaper online
    Is it 'normal' surcharge?
    32/33?k gallon IGP
    38,520
    Does that include installation? not that it is very hard to install yourself. Local pool stuff is always more expensive than online.
    Ask them what they charge to install equipment you buy elsewhere.
    Apr 2012
    Southampton, PA
    44
    installation not included Thanks, Jason! Will ask.
    almost forgot: the guy also said they don't make salt systems bigger than 40K gallons, so I prolly should double check what he says.
    32/33?k gallon IGP
    38,520
    Quote Originally Posted by noopa
    Who is "they"? Hayward does not, but other companies do.
    I am loosing faith in your pool guy
    Apr 2012
    Southampton, PA
    44
    yeah, I know, right?
    If you want something done right, do it yourself
    32/33?k gallon IGP
    Apr 2012
    Southampton, PA
    44
    Do you really want SWG the same brand as the pump? Will you use automation if you don't have much to automate?
    Do you really want a 2 speed pump if you have relatively cheap electricity and just pool without bells and whistles [and not planning on getting any bells and whistles in the nearest future]?.. my brains hurt...
    32/33?k gallon IGP
    38,520
    If all you have is a plain pool then you don't need automation so you can mix and match manufacturers no problem. Get the SWG you want.
    Again with a plain pool, you could run a 2-speed pump on low all the time for circulation and save money. On low it moves about half the water than at high speed, but uses 1/4 the amount of power.
    What size motor you have now?
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Apr 2012
    Southampton, PA
    44
    1.5 HP 'super pump'. It was set to run 12 hours a day... and we have 1.5" skimmers?
    32/33?k gallon IGP
    38,520
    So with a 2-speed, you could run on low speed for 24/7 to get the same water turn over, but would actually use half the amount of electricity.
    Of course you likely may not need to be running your current pump that long and may be able to get by with shorter run times.
    It is also possible that you could get by with a smaller pump/motor (1HP) either 1 or 2 speed since you do not have any need for higher flow rates (waterfall, spa, solar, etc). The smaller pump/motor would save even more money.
    Apr 2012
    Southampton, PA
    44
    Got the Clean & Clear Plus 520 and WhisperFlo 1HP. Very happy so far.
    We have FLOW now [like, 2 times more flow than with 1.5 HP 'super' pump] and sparkling water.
    Didn't get the SWG. Quote from another store: $2,500 for IntelliChlor IC-60 including installation... I dunno, imho, it's a robbery.
    I'd rather be pouring bleach or maybe convince DH to install SWG ourselves.
    32/33?k gallon IGP
