Thread: Ground areas
    Ground areas
    What is the best ways to find out what part of the yard is worthy of holding my 16 x 48 pool?
    Once I find it whats the best way to level it?
    Illinois ground is hard as a rock here.
    Re: Ground areas
    Welcome to TFP!
    One good approach is to block out possible locations with a garden hose or thick rope and try to imagine a pool there. Check out how much shade/sunlight it gets, how walking around the pool feels, how going in and out of the house from/to the pool works and generally get a feeling for how it works for you.
    Re: Ground areas
    Need to add Intex AG 16 by 48. I have a area beside the house that looks flat, except for the divits my golf irons took out.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Ground areas
    Welcome to tfp, blazzinbird
    Quote Originally Posted by blazzinbird
    Then putting a pool there will take away that misery
    My area I chose "looked flat" as well but ended up being 8" off from one side to the other.
    Casey's Avatar
    SW PA
    10,453
    Re: Ground areas
    I do believe mine is 4ft off.
    Good luck with your pool! We like pics... even if you're playing in the dirt wondering what you got yourself into!
