Thread: fillin my sand filter with water
    Jul 2008
    Bucyrus, Ohio
    108
    Ok new liner in...went alot better than I expected..I am about 3" below the return so I know if I ope the valvle to the pump it will fill when it gets to the right level....My question though is this...to fill the filter what do I set the top of my Hayward system to to allow the filter to fill with water?
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    30,403
    Re: fillin my sand filter with water
    Do you mean what position the multiport valve should be in?
    Jul 2008
    Bucyrus, Ohio
    108
    yea what position does the valve need to be at?
    Overwhelmed
    hawkeye's Avatar
    davenport,iowa
    118
    I always just stick garden hose in filter head where pool Skimmer hose attaches to filter head and go easy with water pressure at first, this is the best way to prime it,that way its ready to rock when level comes up or just hook everything up and set hayward to filter it will trickle in.....hope this helps......good luck
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    30,403
    Use the "filter" position.
    22,542
    With an aboveground pool the pump and filter are normally below the waterline so once you open the valves and set the multiport to filter it will start filling with water. You can open the air bleed valve if your filter has one.
