Thread: Taylor 2005 vs. 2006
    May 2012
    Gulfport, MS
    59
    I ordered the 2005 kit by mistake. I thought it was the 2006 kit. Can I still use the 2005 kit to test me water?
    30'x54" Round Vogue Simbio AG ~21,000 gallons
    Pentair Sand Dollar SD 60 w/ Pentair Dynamo 1.5 hp Pump
    Vinyl Uni-Bead 25mil Liner
    Perfect Bottom w/cove
    Taylor K-2005 & K-2006 Test Kit
    22,548
    Re: Taylor 2005 vs. 2006
    You can use it but you need to order the FAS-DPD stand alone kit to go with it. If you could return the 2005 and get a 2006 that would be better but adding the FAS-DPD test makes them almost identical.
    May 2012
    Gulfport, MS
    59
    I can order that from here yeah?
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, you can order it from Dave. See TF100 Test Kit link in my sig and in Bama's sig.
    You're done SLAMing when:
    May 2012
    Gulfport, MS
    59
    k...thx
