Thread: About finished with drainging the water off pool cover
    Kannapolis, NC
    89
    Had some algae on the cover, via standing water. I am curious can or should I use the same garden hoses to fill the pool back up to regular height????
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    Kannapolis, NC
    89
    Re: About finished with drainging the water off pool cover
    I know its a dumb question but had to ask, and now I amgonna go out and pull the cover off and start filling with water, using the hoses that were used, as I am sure the pool water isn't crystal clear anyhow. And I am fearful that I do have other problems out there as my pool water with the cover on looks lower than when I closed. I hope its just me worrying for no reason but we will soon see. Did I say it is suppose to be 93 next Sunday here in North Carolina.
    _________________
    My Pool:
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Unless you fill your pool with trucked in water how else would you fill it? I used our regular garden hose and the water was just fine. Are there any extenuating circumstances that would prohibit the use of your hose?
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Mar 2012
    Amarillo, Texas
    341
    I use the same water hose to wash the dogs, water the yard, add water to the koi pond, and fill the pool. All is good!!
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
