Thread: Pentair Prowler 720 Won't Climb Walls
    New fiberglass pool install. Used subject cleaner for the first time but noticed when it came to walls and steps it would tilt all the way "like" it was going to climb and then reverse itself. Any ideas?
    N Virginia
    -Leisure Moroccan 38' Fiberglass
    -19,800 Gallons
    -Pentair EasyTouch 4 w/IC40 Chlorinator,VS3050 Pump, Clean&Clear Plus 320 Cartridge Filter,Prowler 720 Robot Cleaner
    -1 Skimmer/ 3 Returns/2 Drains/2" Piping
    -3 Fiberstar Pal Treo LED lights/Wirtran
    -TF100 TestKit
    Feb 2012
    Phoenix, AZ
    728
    Re: Pentair Prowler 720 Won't Climb Walls
    Do you have a toe-kick (small ledge about halfway up the pool wall)? They are common in fiberglass pools, and I have seen some cleaners have difficulty getting above them.
    I do have the small ledge but it won't climb at all. It raises up like it is going to climb and then reverses.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
