Thread: Builders in Austin?
    Builders in Austin?
    is there any resource to find suggested builders that folks have used in austin? we are in the infancy stages of this process and are about to interview builders. any help would be appreciated.
    js
    18,000 GAL concrete plaster
    1.5 Hp whisperflow pump
    Pentair Cartridge filter
    Hayward pool vac ultra
    Re: Builders in Austin?
    What type of pool?
    ____________________________________________________________ ______________________
    In the process of building a Lonestar Fiberglass Pools : Savannah in Caribbean Blue. 13,000 Gallons SWG, 4 therapeutic jets, Pentair 1 HP superflow (348023) pump, 200 Clean & Clear cartridge filter (CCRP-160353), Pentair salt cell IntelliChlor IC40, 3 LED lights, 1 skimmer, cantilever coping with integral light wheat color, and salt-rock pool decking finish.
    Ours is still in process (literally everytime we have a major milestone scheduled it has rained). The rain from earlier this week was supposed to be when we laid down the base for the paver decking. The rain from last week was the first time we were scheduled to do it.. march had record setting rains.. etc.
    The pool itself is done though so we are swimming.
    We interviewed a bunch of pool builders and would be happy to discuss.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    keep in mind that this is the busy season so all the subs are extremely busy. my pb was saying you can definitely tell the work done in the summer vs the winter. If you can start the build in the early fall you will get a higher quality build. The crews wont be rushed and will just do a better job.
    Aug 2010
    Austin, TX
    200
    We used Pool Pro. Their designer (Renne Graham) is excellent.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
