Thread: Refill Done, what to do first?
    Pool Temp: 77 Degrees
    PH - 7.5
    FC - 2.0
    CC - 0.5
    TC - 2.5
    TA - 150
    CH - 300
    CYA - 57
    I bought tons of bleach and have Acid, just don't know what to do first to maximize my first BBB launch...
    Thanks in Advance!
    Jason H. DFW, Texas
    22K Gallons, DE Filter, In-Ground Pebble-Tek
    Spa that drains into the pool, two built-in areaters and waterfall (Rarely Used)
    Feb 2012
    Phoenix, AZ
    728
    Re: Refill Done, what to do first?
    Do you have a SWCG? That CYA is a little high if you don't have one...but maybe that's why you re-filled? Was it a complete refill or just partial? Also, how does your water look?
    If you water is clear, I would just focus on getting your FC up to 6 or 7.
    None of the levels look particularly alarming to me.
    With CYA around 60, you want to keep your FC at 5 or above (mostly above).
    You are most likely going to want to lower your TA, though there probably isn't any rush on that.
    Quote Originally Posted by blakej
    I did a partial drain/refill. Actually this is my 2nd one already since I didn't get my TF100 until this week and Leslie's was using the same strips I was. CYA was off the charts.
    The water is clearish, I'd planned to shock it to 24 based on the CYA chart, but didn't know if it would be better to get the TA a little lower first or try and adjust the PH before shocking.
    I have some recurring algae that I need to nuke.
    Thanks!
    Jason H. DFW, Texas
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by techrancher
    Thanks!
    Shock first and confirm when you are done shocking w/the three criteria listed in my sig in red.
    After you are done shocking, each time the pH hits 7.8, lower it to 7.2 with muriatic acid. Over time this will lower your TA. There is not need to hurry the TA lowering process unless your pH is rising at an annoying rate. Then you could use the "how to lower your TA" article in PoolSchool.
    You're done SLAMing when:
