Thread: 8 boxes of borax and 2 gallons and change of acid
    Dallas, TX
    227
    Is it a problem if I take it from 0 to 24 ppm then do the test next weekend? Only have 8 boxes of borax, and I bought out the two walmarts near me.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: So you want to add borates to your pool--Why and How
    Quote Originally Posted by CarrolltonTXPool
    That's how I did mine, two separate doses.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Dallas, TX
    227
    Ok all done. 8 boxes of borax and 2 gallons and change Of acid. Should I test now for PH and TA and off they are off adjust accordingly? Or wait till tomorrow? Test strips will be here the or wed. Never been real sure of my pool volume so this will help since borates start at 0 ppm.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: 8 boxes of borax and 2 gallons and change of acid
    You can test the PH and TA now. Borates will be mixed in a few days.
    Dallas, TX
    227
    Ok, great thanks.
