Thread: Question abount adding Cyanuric Acid
    May 2012
    South Carolina
    7
    Is there any tricks to adding Cyanuric Acid without pouring it into the skimmer? I don't want to lose it while backwashing.
    18,000 Gallon AG, Vinyl liner, sand filter, Hayward 1 HP Pump TF 100 Test Kit.
    Re: Question abount adding Cyanuric Acid
    If you are likely to need to backwash in the next week, put the CYA in a sock, and hang the sock in front of a return jet, so it gets caught up in the jet when the pump is running. Then you don't need to worry about backwashing.
    May 2012
    South Carolina
    7
    Great! I'll try that.
    Thanks.
