Results 1 to 9 of 9
Thread: Water in the gas line??
    Is this a common cause of a pool heater not firing up? if so what are the remedies?
    Thanks
    Plaster In Ground, with Waterfall Spa. Raypak Heater, Nautilus DE Filter DNS48. Built about 2000.
    Feb 2012
    Stowe, VT
    59
    Re: Water in the gas line??
    Are you sure there is water in the gas line, and not air?
    If so it depends on how it's getting in, some older underground pipes can corrode allowing water to seep in. Also keep in mind the pressure of gas is relatively low therefor water will find it's way in. In this case, digging it up and replacing the piping is best solution. Just make sure not to use the heater until the water is removed and you are sure there is no more water.
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    While water can occasionally get into gas lines, but that is really rather unusual. Heaters failing to startup is fairly common, and not usually caused by water in the gas line. Unless you have some specific reason to believe there is water in the gas line I would look elsewhere.
    The most common problem that prevents heaters from starting up in the spring is debris in the combustion chamber, often brought in by rodents.
    I'm not sure. This is a possible cause that has been suggested by a pool guy who hasn't seen the problem yet. I was wondering how common this is? I have a post on this forum as my Raypak won't fire up. The gas line would be about 10 years old. I wold have thought that gas lines are very strong but maybe this is a common problem?
    While water can occasionally get into gas lines, that is really quite unusual. Heaters failing to startup is fairly common, and not usually caused by water in the gas line. Unless you have some specific reason to believe there is water in the gas line I would look elsewhere.
    Yes, I would think it uncommon also, that's why I posted. I'd like to pull the drawer out that holds the burners but don't know if that's a big job or not. Still looking for someone in Houston area who sounds like they know what to do to fix this.
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Why do you want to pull the burner tray? Do you smell gas when it tries to fire? Can you hear it sparking and can you hear the gas valve click open when it tries to fire? IS there a problem with the regulator and it's providing gas to the unit?
    You really do need to find someone in your area that works on these units to get down to the cause. Try calling this company and ask if they can refer you to someone that works on gas pool heaters. This is a supply house for pool products and they probably know someone that uses them that they can recommend.
    Superior Pool Products - (281) 776-0808
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Apr 2009
    Burlington, ON, Canada
    344
    I actually had this occur to me, however, the gas line was left disconnected from the heater over the fall and winter months and when it was reconnected the line was not blown out (the apprentice did the hookup in the spring). The heater would not start. The gas installer came out (after 20 lashings to the apprentice) and blew out the lines and all's been good ever since (this was in 2008).
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Drip legs on the gas run usually prevent such, do you have them? Short stubs of pipe that extend down past the tee on vertical runs.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    May 2011
    Orange County, CA
    696
    How is the gas pressure? Black iron pipe that is used for house gas lines is sometimes used for underground gas lines and these are notorious for rusting rather quickly. Even galvanized pipe can corrode depending on the soil chemistry. When we bought our house, I tried to run our heater, and it just wouldn't start. I called a pool guy out and he first thought it might be a regulator or igniter issue. After about an hour of playing around with this, he tested the pressure and found it to be very weak. It turned out that the gas line was pretty much corroded through. This was confirmed by a faint odor of gas in a couple of places in the yard where the line was run. We had to re-do the line. I called in a plumber and they quoted me $9200! I literally laughed in his face thinking I could do the line myself for much cheaper. I hired a couple of guys to dig a trench, and then talked to our local building inspector. He requested sch. 80 PVC, but I soon found out that gas lines need to be done with yellow PE pipe, and this generally requires special plate welders. So, I called around and found a plumber who would do the line with welded PE pipe, including the appropriate PE to coated iron risers for $1200. This was very reasonable for a 150' run of 1 1/2 inch line with a T off to the BBQ island. So, for about 1/4 of the cost of the original quote, the line was done. The inspector did a pressure test and all was good and up to code.
    Obviously, I wasn't happy when I learned that the gas line had to be replaced, but it's good to know that it is much safer now and likely to last much longer. You should definitely make sure to have the gas pressure tested.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
