Thread: Measuring device for HCl
    Feb 2008
    Denton, TX
    5,061
    I just want to be double certain about what I am doing here. Knowing that there are certain acids that attack glass (hydrofluoric acid for example), am I safe using a Pyrex measuring cup for muriatic acid?
    Many thanks!
    Craig
    Attached Files Attached Files
    Yes, but be careful pouring the HCl. It can damage your skin.
    Others can chime in with their favorite measuring tricks with HCl
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    mas985's Avatar
    Pleasanton, CA
    11,737
    I don't use a measure cup, I mark the outside of the gallon jug of acid with a stick that I calibrated to quarts. I can usually eyeball 1/4 to 1/2 gallon without the marks but pints are a bit harder to do. It is probably close enough to mark the jug in eight equal increments though you could make a calibration stick like I did using a measuring cup and an empty jug.
    Mark
    30,419
    My approach is the same as Mas985's. It always made sense to me to handle it as little as possible. That said, I use it in 1/2 gal increments most of the time so auper accuracy was never an issue.
    Feb 2008
    Denton, TX
    5,061
    Well, I guess I could mark the outside of the jug in ounce increments. It's just that there are lots of ounces in there. My pool is small and I never have to use more than about 8 to 10 ounces at a time. But anything is better than having to mess with it so much by pouring from one container to another and risking splashes.
    You guys are great! Thanks!
    Craig
