Results 1 to 9 of 9
Thread: High PH and TA
    High PH and TA
    Hi,
    I've checked PH few over last couple of months and it's consistently high.
    TC - 5
    PH > 8.2
    TA - 150
    TH - 320
    CYA - 80
    According to pool calculator, I should add 38 oz of Acid to bring PH down to 76. Should I add it all at once or do it slowly over couple of days.
    Also, should I worry about TA levels and try to bring it down?
    Northern CA. 19K gallon Gunite pool, original plaster, DE filter, Kreepy Krauly legend, 1 HP filter.
    22,551
    Re: High PH and TA
    You should add it all at once in front of a running return.
    Don't worry about the TA right now. It will come down as you add acid to bring the pH down.
    30,423
    Re: High PH and TA
    Adding importance to what bama said, you should never let it stay over 7.8 for any length of time.
    I suggest you test your pH at the very least twice weekly and bring it down immediately if it is higher than 7.8
    Re: High PH and TA
    Thanks guys. I added acid couple of days ago and PH was down to 7.8 today and water is also clearer. I added some more today to bring it down to 7.6
    What FC level you guys recommend for me given the results above?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: High PH and TA
    Quote Originally Posted by twitter
    With CYA of 80, FC should be between 6 and 11, and never below 6.
    You're done SLAMing when:
    30,423
    Re: High PH and TA
    twitter,
    Have you found the FC/CYA chart in Pool School?
    Re: High PH and TA
    I found the FC/CYA chart and will follow it. I've been doing OTO test for chlorine so far and kept total chlorine more than 5 most of the time. I received TF-100 yesterday and will start using it for more accurate testing for FC/CC. But it may be too much work for day-to-day testing. What if I mix equal parts pool water with tap water and use it for OTO test, then multiply the result by two. Would it give decent results for daily testing?
    -Twitter
    Re: High PH and TA
    Not really, dilution doubles the error, which is already fairly large. What I do is use the OTO test just to make sure that FC is fairly high, without getting a precise number. Then once or twice a week I do a FAS-DPD chlorine test to get an exact number and adjust how much chlorine I need to be adding for the next week. That works fairly well as long as you keep track of things that might require extra chlorine (a really hot day, a major storm, extra people swimming) and do extra testing right after anything like that.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: High PH and TA
    -Twitter
    Naw, the FAS-DPD test is easy. If you want to conserve the reagents, use a 10ml sample and multiply each drop by .5. You'll get the hang of things within a couple weeks to where you can predict with considerable accuracy what readings you'll be getting when you test. That's when you can slack off a little.
