Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Few questions about my pool
    Jul 2010
    Longwood, FL
    151
    1. I noticed my return water at bottom of pool is coming from one point only. It used to randomly rotate from different points.
    2. My cell 15 is about 6 month old, I cleaned the cell with the hose water. Now the display says inspect cell ?
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    38,267
    Re: Few questions about my pool
    The AquaRite will indicate inspect cell every 6 months or so as a reminder to check it ... does not mean anything is wrong you have to hold down a button I think to reset the light. {EDIT Hold the + button to reset the light}
    Do you have an in-floor cleaning setup? not sure if that is what you are talking about.
    Jul 2010
    Longwood, FL
    151
    I have a black circular thing by pump with 6 pipe going into it, I think that's what control it, dont know how to test it though, on top there is knob says run/pause , it's on RUN
    Support the site
    Jul 2010
    Longwood, FL
    151
    Yes exactly the same
    22,544
    What is your filter pressure when the cleaner is off?
    What is your filter pressure when the cleaner is running?
    Jul 2010
    Longwood, FL
    151
    My guage reader is so fuzzy its hard to read ............ but I will try to get it .
    22,544
    If it's not readable you should replace the gauge.
    Jul 2010
    Longwood, FL
    151
    Any good source for buying the guage ?
    I know I have to use teflon tape on the threads.
    22,544
    MOst pool stores carry them in stock, also the big box stores will have them.
    Jul 2010
    Longwood, FL
    151
    Thanks I will update once have the pressure.
    The valve should also have a gauge. Can you also report the valve pressure gauge reading?
    Support the site
    Jul 2010
    Longwood, FL
    151
    James. On my both guages I can't see anything. I am going to replace both during weekend. Apart from teflon tape. Do I need to seal it from outside when its done. I notice some white glue kind of stuff on both.
    Regards
    Jul 2010
    Longwood, FL
    151
    I am planning to get 100 PSI guage today from home depot
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Quote Originally Posted by sunny8088
    This is similar to the one I got a few years ago. Still gauging fine. My pool store 5.98 gauges lasted a year maybe.
    http://www.ebay.com/itm/NEW-WIKA-PRESSU ... 4601d29a87
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    22,544
    I think a 0-100 psi gauge is too wide a span to be useful. I'd go for a 0-60 psi or perferrably a 0-30 psi.
    Jul 2010
    Longwood, FL
    151
    Ok Sir. I will get the 60 PSI then. There is no thanks button here like other sites , so I need to post message to thanks
    Thanks
    I would be cautious about using too much Teflon tape. It's easy to use too much and that can cause excessive stress on the fitting that you are screwing into. My preference is to use only about 2 to 3 wraps of tape and then apply a thin layer of Permatex No. 2 over the tape. The Permatex is a black liquid that has good sealing properties.
    http://www.permatex.com/products/automo ... ealant.htm
    Support the site
    22,544
    Just as an opposing opinion. I hate permatex for anything except gas lines and don't like T-tape either. I always use Teflon thread sealing paste. It doesn't gum up stuff and it seals well.
  20. Back To Top    #20
    Jul 2010
    Longwood, FL
    151
    My Cartridge PSI is 32 and my valve PSI is 10-11 !
    Anything needs to be done , still water comes out from ONLY only outlet
