Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: 1971 In-ground, Forgotten no more.......
    Jul 2011
    Hunterdon County, NJ
    32
    I recently purchased a house with an old in-ground that has been closed up and forgotten about for a few years. I'm bringing it back to life on a budget, so there's going to be lot's of sweat equity going into this one. Follow along if you would like. Here's the plan :
    Remove old wood deck and what's left of the concrete pool decking. (done)
    Bring bonding up to code. (none now)
    Move equipment back about 8 feet. and re-plumb
    Install concrete paver decking 6' out around 3 sides and 16' off the shallow end with a fire pit.
    Install pool fence
    Run new electrical in conduit out to the equipment pad
    Install new timer, sub-panel, timer, and convenience outlet at the pad
    Un-swamp the swamp
    Light fire, Open beer, Watch the sunset.
    Here's where I'm starting, I'll post new pics as I go.
    1971 Anthony 20x40 In-ground Vinyl, 1Hp Super Pump, 244t sand filter
    Big dreams, no cash, but a whole lot of creativity mixed in with little bit of stupidity!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: 1971 In-ground, Forgotten no more.......
    Looks like you've got your work cut out for you! That pool looks like it's full of used oil. Please update us as you make progress!
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Wow, you've got your work cut out for you but the potential looks incredible as well. I love seeing projects like this, where people take neglected pools/landscaping and make them shine.
    Personally I'd focus on getting the water straightened out and then take your time and plan out the landscaping and decking/patio.
    Good luck!
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by Melt In The Sun
    Very true, but it will sure make for some good before-and-after pics!!
    Apr 2010
    Buckeye, AZ 85326
    619
    Good luck with this project. These are some of my favorite types of posts. Big projects with befores and afters. Are you flipping this house or in it for the long haul?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Jul 2011
    32
    I plan on keeping this one for quite a while. It still needs a lot of work inside too, but the pool is priority 1 right now. Insurance co. wants a fence fast, but I refuse to do and excavating next to a brand new fence. So that has dictated my order of operations here. Once I get all the ground work, plumbing and electrical done, I will start shocking the pool while laying the pavers. I busted my butt the last two weekends getting it down to a clean slate, so this weekend I have a mini excavator coming so I can get the ground prepped for the pavers and do a little grading around the area to help with the drainage.
    30,432
    Welcome to the forum. Great project and you have a great plan. We'll all help any way we can!
    Mar 2012
    Mountain Brook, AL
    112
    I'm excited for you. I'm starting a redo as well in a week.
    I used to live in Los Angeles and your pool reminds me of the La Brea tar pits. I think I would drain and refill instead of shock. There might be a Buick in there.
    I love crazy pics - you should pose the family laying out and pool partying in front of it while it looks that way
    13,500 gallon IG Diamond Brite Super Blue, Pentair Superflo 1.5 HP 2 speed pump, 300 lb Hayward Sand Filter, Hayward Swim Pure+ SWG, Four 4X20 Fafco Solar Bears, Jandy Lite2 NG Heater, Borates, Blue Diamond Robot, TF100 & Refills, Taylor SpeedStir
    Jul 2011
    32
    Ok, time for an update. Last weekend I was able to tear out all of the remaining pool deck and the wooden deck next to it. So it's down to a clean slate. This past weekend I rented a machine and excavated down about 10 inches around the perimeter of the pool where my planned paver installation is going to be. I also trenched for a drain pipe around the perimeter to capture the rain run off and discharge it downhill past the house. The old arrangement was pitched toward the house and I can see where the foundation wall on that side was usually wet. So this and some grading and drainage near the house should hopefully solve the situation.
    I'll get some of the excavation shots up later this week. I forgot to take them before leaving on Saturday.
    Jul 2011
    32
    I guess this is the part where it gets worse before it gets better.
    I have all the excavating done and have made quite the mess. The paver are is nice and lever with a slight pitch away from the pool. Next is to install all my drainage piping that was delivered yesterday. Then I want to get the gravel base down, run a string line to establish where the finished grade will be, then hide all the dirt I dug up.
    Here's what It looks like now.
    Columbus Ohio
    178
    You have quite the project infront of you but I am sure it will be well worth all the hard work ahead! I love watching these and seeing the transformation take place. It looks like you have a great location and you are heading in the right direction!! Keep us updated!!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Mar 2011
    Sunny Central Florida
    91
    Um.....have you pressure tested the pipes to make sure there aren't any leaks? I'd hate to see you put down all those pretty pavers and have to rip them up again.....
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Mar 2011
    91
    (Says the woman to just paid $400 to have part of her deck cut & plumbing replaced because one of the return jet T connections was cracked and leaking 1" a day.....)
    Jul 2011
    32
    I have not pressure tested them, but I do know I'm not loosing any water. I do plan on getting the equipment running to make sure everything is OK before running before setting the pavers. I figured the paver work will be a good time to start shocking the pool since I'll be there working next to it anyway I can keep an eye on my chlorine levels
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Looking good!!
    Apr 2012
    Bonner Springs, Kansas
    109
    Wow - the work so far looks great! Quite the undertaking!
    16'x32' -> 3' shallow, 8' deep ~22,000 gallon igp - Vinyl Liner.
    Sand Filter: Jacuzzi 225l-7 Sand Filter - 250lbs
    Pump: Hayward Max-Flo XL 1hp
    SWG: CircuPool RJ+ 60
    Water Source: Home Tap water (TA:230, CH:220)
    Jul 2011
    32
    Moving along here.....
    I only have one day to work on things this weekend, but I did manage to get all the pipe for my perimeter drain in place and pitched properly. I have to pull it one more time and put the filter sock on it, but at least there will be no more digging involved. With all this dry weather and the clay here I think it was easier breaking up the concrete than digging in this stuff.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Make sure you put a LOT of drain stone around that pipe. Even with the sock and no drain stone, it will get clogged.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Jul 2010
    Oklahoma City
    71
    You need to flip that drainage pipe over, the holes should be pointing down, not up.
  20. Back To Top    #20
    Jul 2011
    32
    Thanks all.
    I think I'm going to return the sleeve and pick up some fabric instead so I can line the trench before the clean stone goes in.
    Have no fear I will be turning the pipe before I cover anything up. That was just laid in place so I could get the bottom of the trench right and everything cut to length.
