Thread: Solar Heater MI
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Solar Heater MI
    Anyone from Michigan use a Solar pool setup? Whats a rough price for an entry level setup? I have a raypak 2100 but its costly, wondering if my money would be better spent on a solar setup.
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    Solar Heater MI
    I have a solar heater. I ran it on top of my garage. I use the black sprinkler tubing ran about 20 feet under ground and then ran the rest up the downspout of my gutter. You will need a way to regulate the water flow to the heater. To much water flow will provide no heating but a slip stream helps much more. I don't see a whole lot of extended season time. Once it's starts getting cold we're done.
    34k Gal., IG 20x44 Vinyl, Hayward Super Pump 1.5HP, Hayward Pro Sand Filter, Jandy Lite2 Heater
    38,248
    Re: Solar Heater MI
    Actually the solar heating efficiency goes up with high flow rates. You may not feel HOT water entering the pool, but that is not the way solar heaters are supposed to work. You can add more BTUs of heat to the pool if there is only around a 2 degree rise in water temperature across the heater.
    Basically you are better off having a LOT of water with a couple degree temp rise that a small amount of water with a high temperature rise. This is discussed in many threads here in the forums.
