Thread: salt level consumption rate
    Jul 2010
    Longwood, FL
    151
    My aquarite was showing low salt last week about 2700 , I bumped it up to 3100 7 days a go.
    Yesterday again it shows 2800, My pump runs 8 hours a day.
    Can it use salt that fast ?
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    38,248
    Re: salt level consumption rate
    The salt does not get "used up" the only way for the actual salt concentration of the pool to lower is through splash-out/backwashing.
    There are actually 2 readings in the aquarite an average and the instantaneous concentration. The instantaneous can vary some while the average should be pretty stable. Do you have the test strips to measure the concentration yourself?
    EDIT: How old is your setup? Could the cell be starting to go bad? What is the full list of pool levels to determine if scaling could be affecting the cell?
    Mar 2012
    Northern California
    59
    Probably a dumb question here, but what measures the salt saturation? Is it the salt cell or is it part of the flow sensor?
    32,000 Gallon Plaster Pool
    Hayward Aqua Plus 40k Gallon Chlorine Generator w/ Controls PL-PLUS
    Pentair IntelliFlo Variable Speed Pump
    Polaris 3900 Sport Automatic Pool Cleaner
    Polaris 3/4 hp Booster Pump
    Pentair/PacFab Nautilus D.E. Filter 48 Sq Ft
    The AquaRite units estimate the salt level from the current to voltage ratio in the cell. Other units work in other ways. One effect of the AquaRite approach is that the salt level starts reading lower and lower than actual when the cell is starting to fail. Adding salt can keep the cell working for a little while, but if you do that you end up with a very high salt level and the new cell will refuse to run when you install it because salt is too high.
    Salt can also go down if you have a leak and an auto fill system replacing water without you noticing.
