Thread: First test this year
    I have an ultra intex salt water pool. 8500 gallons.
    FC .5
    CC 0
    PH 7.4
    TA 90
    CYA 0
    I know that I need to add stabilizer and bleach. Do the rest look ok? PH and TA??
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: First test this year
    ph and TA look great. As you already know, get some CYA in there then adjust your FC level minimum to that CYA level using the chart in poolschool: http://www.troublefreepool.com/pool-...ya_chart_shock or you can use poolcalculator.com
    Feb 2008
    Denton, TX
    5,061
    Good advice by linen. Here is a good suggestion on reading for you as well.
    pool-school/temporary_pool_guide
