Results 1 to 7 of 7
Thread: Rising PH
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Rising PH
    It's probably here in the forum but I can't find the answer so I'll ask it again. What causes PH to rise?
    Thanks
    Attached Files Attached Files
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Guest
    Outgassing of carbon dioxide. Aeration speeds this up. Also, in plaster pools the the plaster finish itself can cause a pH rise by leaching alkaline material into the water.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Thanks, but what exactly does that mean?
    Guest
    Perhaps this thread from Poolforum might help explain it. Check my answer in the second post.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Thanks, now all I have to do is understand it.
    Guest
    Ok, here is the REALLY simple answer. Your pool is carbonated, we call the measurable part of this (which are carbonates and bicarbonates) TA. The non measurable part (by our testkit) is carbonic acid or carbon dioxide dissolved in water (not completely the same but for our purposes here they are). You might know carbonic acid by it's common name, club soda or seltzer water. When you shake up a bottle of club soda (areate it) it goes flat (carbon dioxide outgasses). You have now decreased the amount of carbonic acid (keyword here is acid) so the pH rises.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Got it! Thanks
