Aside from SVRS what are the differences between 011017 and 011018? And is it worth the $200 difference?
maxepr1 said:Mark, kind of stuck between a rock and a hard place. Power co. will give a rebate only for Intelliflo and not 2 speed?? If I run power directly to pump from breaker then use the pump timer and I would just have to match Aqualogic timer to pump timer for SWG, I think? Waiting to here back from power co. on explanation.
mas985 said:The SVRS has a built in timer. How do you plan on controlling the pump? If you want to interface with the Aqualogic, you will need the Intellicomm communications center which runs about $200. But even then, it will be for only two speeds.
