Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: How to achieve weekly pool visits.
    I am now maintaining my mothers pool who lives a distance away and is not capable of doing it her self
    I can only make it to her house ever 6-8 days and do NOT wish to use triclor or anything that would RAISE the CYA
    Our current CYA levels are 43 ppm
    and i did a 12 hour test to find we are loosing apx 38 percent of the chlorine over 12 DAY TIME hours..
    this seems to be a stable trend as loss over each 3 hour period was identical.
    with this data i made the following chart
    10 0 hours
    6.2 free cl left at 12 hours or 0.5 days
    3.844 free cl left at 24 hours or 1 days
    2.38328 free cl left at 36 hours or 1.5 days
    1.4776336 free cl left at 48 hours or 2 days
    0.916132832 free cl left at 60 hours or 2.5 days
    0.56800235584 free cl left at 72 hours or 3 days
    0.352161460621 free cl left at 84 hours or 3.5 days
    0.218340105585 free cl left at 96 hours or 4 days
    0.135370865463 free cl left at 108 hours or 4.5 days
    0.0839299365868 free cl left at 120 hours or 5 days
    is there any level of CYA and FCL that would allow this to work. while .5 is ok at 0 ppm of CYA its kill time is far to slow at 50 ppm
    ( made this php script to find cl levels at different loss percent and starting fcls)
    <?php
    <form action="cya.php" method= "POST">
    <input type = "text" name ="start" value="starting fcl" size= "20">
    <input type = "text" name ="disa" value="disapation in percent" size= "20">
    <input type = "text" name ="times" value="interval for disapation in hours " size= "20">
    <input type = "submit" name="submit" value ="click to calculate">
    </form>
    <?php
    $hours=0;
    $start= mysql_escape_string($_POST["start"]);
    $disa = mysql_escape_string($_POST["disa"]);
    $times= mysql_escape_string($_POST["times"]);
    $disa=(100-$disa)/100;
    echo $start." 0 hours
    </p>";
    while($start>0.1){
    $start=$start*$disa;
    $hours=$hours+$times;
    $dayss=$hours/24;
    echo $start." free cl left at ".$hours." hours or ".$dayss." days
    </p>";
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: How to achieve weekly pool visits.
    A chlorinator or Stenner pump could keep the chlorine in line for a week at a time. Remember that chlorine demand is going to go way up as the days warm.
    But think long term. If mom isn't able to do any pool maintenance then there are orher household chores she can't do also? Is it time tohave a difficult conversation about downsizing?
    CYA can get over 100 before causing too much trouble. Tabs might be a good temporary solution.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Thats no fun! This has become a science project for me now. and MY OCD means i must make it work
    without the use of floaters or anything else.
    just liquid CL
    cya
    acid
    bakingsoda
    and borate
    ordered enough borate to bring her pool to apx 40-50 ppm and am thinking this will help with algae and further reduce CL loss due to non UV related causes.
    I am going to run over in the AM to get a true 24 hour reading since so far i only have daytime 12 hour reading i am hoping that 12 hour night will have much less loss. ( 12 hours was about 38 percent loss and im hopping for a total 24 hour loss of 45-50) as i can make this work.. 16 ppm (little less then 2 gal of CL ) will reduce to .5 ppm at 5 day. if my math and logic are sound.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Put your OCD mind to work on this idea and see if you can solve it for us.
    30,432
    You don't say where you live, but chlorine usage will easily triple in the hot summer months.
    Their are cool months? Not here lol it's summer already in Florida
    Also 38 percent 24 hour loss. Checking again in 6 12 and 24 hours
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Does the pool get a lot of usage? If it's a pool that gets used rarely or only once a week or so then you could raise the CYA and keep a higher FC through the week.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Raise cya to what and Fcl
    To what? At about 60 ppm cya maxes out on its benefits no?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I would say bring it to 70-80 the FC according to the chart should be around 6 but if you are getting minimal usage you can go lower.
    pool-school/chlorine_cya_chart_shock
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    mas985's Avatar
    Pleasanton, CA
    11,742
    Chemgeek has a few really good charts regarding CYA and chlorine extinction in this thread. There are diminishing returns for higher CYA but I found that running at 80 ppm gives a bit more protection than 60 ppm.
    Also, as an alternative, it is possible to properly run a pool on trichlor tabs. If the pool has a sand filter and requires frequent backwashing and/or removing water due to rain, the CYA level will not climb as fast and may even remain stable at some point. It just requires monitoring the CYA level to make sure it doesn't get too high.
    Mark
    FL is one of the cheapest states for weekly pool maint.
    You could get someone for $60-75 per month including chems.
    Julie
    I have a small (3,750 gallon) in-ground, Viking pool - 2hp Jandy pump, AquaPure 700 Cholorinator, Jandy Aqualink, and Jandy CJ250 filter
    Hmm most I found in the 60-75 range only did Chem or If they did clean they charged for chem
    But still question remains how do they get away with once a week?
    I see most of then only use liquid cl or dry never any of the "pucks"
    Jun 2011
    Long Beach, CA
    2,790
    What do you guys think about adding a phosphate reducer such as pool perfect in this situation? It seems the pool will not have much load if any and it would help eliminate the algae food. The sanitation might not be perfect but it might help control an algae outbreak if the FC gets low.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    There are some services in Arizona that do weekly visits with great success, using chlorine gas and very high CYA. The CYA is maintained >100, and each week the pools get injected up to somewhere around 20 ppm FC, which is high enough that there's still some left at the end of the week. I don't see why the same thing wouldn't be possible using bleach.
    Still, I think an SWG would be an easier solution.
    According to all the charts retention seems to cap out at 99 percent an hour for any cya above 60 .
    After talking with some pool guys who do weekly maint
    I think I will go with 50 cya and bring the pool to a cl level that leavs
    0.1-0.5 ppm for the next week
    I am having fun experimenting . Yesterday for example only had 10 percent cl loss for the whole 24
    Hours
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    I'm suprised noone suggested this. Using an SWG would work and you don't have to add any chlorine. The only thing I add regularly is Muriatic acid since my pH climbs with a waterfall. I could easily maintain my pool once a week with my SWG during the summer.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by attr
    I would aim for higher than 0.5 for your FC droop. Poolcalculator gives me 4 as a minimum at 50 ppm CYA. Is the pool being used during the week? I am thinking if you have no bather load, maybe a cover and also no organics (leaves, pollen, etc.) getting into the pool, you might be able to get by with a lower FC.
    By the way, I third the vote for a SWG.
    Ok I will look into a swg however I think my point of .5 ppm was missed this would not be the value all week just when I return. It would be about 1 ppm the day before 2 before thy and 4 before that again just talking about loss to uv
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I still feel that is to low of a droop. I would shoot for something higher, especially if there are no swimmers during the week...by the way you haven't answered that question, will there be swimmers in the middle of the dosing cycle? If there are swimmers, then it is more of a balancing act and even more of a candidate for the swcg or liquidator.
  20. Back To Top    #20
    Maybe gets light use once every other week
