Re: Doughboy help
Tried to update pics but it seems I can't tonight. Progress has been slow. This is a used pool I disassembled and am reinstalling, so my posts are partially still assembled. After putting the bottom track together with the posts I decided to put together the top rails to get an idea how square it is. I'm using a laser transit level, the only way I could do this. 2 things don't seem quite right but might be typical and or less noticiable with a wall and water installed.
1) the flat sides to my oval, 3 panels each, my transitions aren't square with the panel between the butresses. That wouldn't bother me it they look similiar, but 1 goes in a few degrees and the other out a few. Its does the same on each side of the pool.
2) A few of my legs aren't square, they seem to lean a bit, like the bottom rail isn't quite aligned with the top.
I think the 1st problem might be fixed by realigning the support butress pieces. Jeez I'm getting tired of adjusting and leveling! 2nd problem might be a symptom of the first, or maybe will be readjusted with wall install? OR is it common for the straight walls to have a little zig zag? My only comment on going inground is, beyond digging the hole, it seems to take a lot more effort, I'm leveling in bedrock with a pick axe! Waiting on my liner to be delivered, hope to have things parsed out before then.
