Thread: looking for dig Specs for true L
    Oct 2011
    15
    Does any one have dig specs for a 20x30x46 true L. Its a kit pool with 3'6" walls. Im trying to get my dive hopper and slopes into the hopper correct. Thank You!
    South Central NJ
    3,192
    Re: looking for dig Specs for true L
    Without a desired depth stated, kinda hard.
    Scott
    Owner of - PoolGuyNJ LLC
    The kit should come with dimensions so that the liner will fit correctly. If not, then you should check with the supplier or manufacturer for the dimensions.
    Support the site
    Oct 2011
    15
    Sorry 8' deep 3'6" shallow. No specs because I'm building the forms myself.
    Does the kit come with a liner or a diving board? If the kit comes with a liner, it should come with dimensions. If it comes with a diving board, then the board should come with minimum dimensions and specifications. The pool will also have to conform to local code, which will probably include a requirement that the pool conform to ANSI/NSPI-5 (American National Standard for Residential In-ground Swimming Pools).
    http://www.divingboardsafety.net/Standa ... -pools.pdf
    Support the site
