Thread: Hayward Goldline freeze protection
    Can someone please tell me how to change the freeze protection temperature on my gold line. It's factory set to 39 I want to set it to 33?
    Thanks
    Re: Hayward Goldline freeze protection
    If you have an AquaLogic system, or one of their other systems derived from that one, the freeze protection temperature is on the Configuration menu under Filter Pump Config.
    sweet, thanks i'll look tomorrow.
    Thanks.
    Thanks to Jason's help I changed the temp to 33.
    Dose anyone have a opinion on that temp? is it too low or should be ok?
    South Central NJ
    3,192
    Temp probes are always +/- a few degrees. I would set it to no less than 36.
    Scott
    Owner of - PoolGuyNJ LLC
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by dankfoot
    It depends on how cold it gets, how long it stays below freezing and if there is a wind break for the equipment and also how much of a risk taker you are. We get below freezing every year but never more than about 6 hours at a time so I don't use freeze protection at all anymore. It takes much longer than that for water to freeze in a 2" pipe let alone a filter or pump. However, for those areas where there is a longer duration of freezing conditions and/or where you also experience a lot wind with freezing conditions, you may need to set the threshold higher. A good way to tell is to put a couple of inches of water in a bucket next to the equipment. That will freeze long before any of the equipement will and can give an idea what you can get away with before setting the threshold too low.
    Mark
