Mark- Just wondering what you think of this statement that I got from a Pentair Pool Forum. I know that you said it would make it worse but wanted to see if this reply post made any sense at all to you? Thanks, Jake
"So without even running any calculations I can tell you that at that distance if you expect to get good flow you would need 4" suction, however you do not need that much flow to handle 5 jets for each pump. We typically plan for about 20gpm for a jet, but they usually specify as needing 10gpm. a VS pump with 4" suction, 3" return would be able to give you 100-120gpm. So maybe a bit low to handle all ten jets, but you would not be unhappy with the pressure. (those are general volumes without knowing the exact system, elevation changes, fittings, valves, etc)
You need to get someone who understands Hydraulics to review the system.
I would start with the idea of removing a pump, and sharing that suction with you vs pump (2-2" pipes are not even close to 1-4" but it is a start.) If you try to run the pump at full speed the velocity will be extremely high, potentially unsafe for the swimmer, against code, and extremely inefficient.
Start by reading an old blog post of mine to get you into the mind set of how to use a VS or VF pump.
http://poolfyi.com/profiles/blogs/why-t ... s-the-only.
With automation, you can use the VS pump to do multiple jobs but changing speeds and valves, maybe allowing you to share suction to decrease velocity, increase flow, and make you happy with the jet output.
You should also make a quick check of the jet orifice. Even the smallest debris or stone will cause the jet to even suck water sometimes."
