Thread: POOL PILOT 220-36
    DONNIE's Avatar
    Mar 2007
    OKLAHOMA
    122
    POOL PILOT 220-36
    Does anyone offer a tube and connectors to replace the SWG cell? I was thinking about taking it in the house for the winter. Can any pool supply make one?
    Donnie
    8500 Gallon Fiberglass IG / Sta-Rite pump,cartridge filter & heater / PoolPilot Dig 220-36 SWG / Testing w/K2006
    Ft Lauderdale, Florida
    1,455
    Re: POOL PILOT 220-36
    Donnie, you need the specific unions to do that. The Union half piece and locking nut, 2 each, are part numbers, #312-A and 312-B, which are the union pieces that are glued to the cell, then you would only need to cut a section of 2" pipe to the same length as the cell and ensure when you glue it, it is the same length as the cell.
    Another option would be a spacer Cell, #APK0006, which is a hollow cell with the unions attached.
    Final option, we make a cap kit that will attach to the upper portion of the manifold and block off the water from flowing up, and instead, flow through the bottom manifold check valve. This is part number # 996, manifold cap kit.
    These are all special ordered items, and you will not find them in stock at any pool store.
    The union pieces are the cheapest option...it's about $22. The manifold cap kit is about $36. The spacer cell is about $56.
    Contact JoshU at Saltpoolguys, who offers discounts to TFP members.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
