Thread: Gauge meter
    Jul 2010
    Longwood, FL
    151
    Gauge meter
    My gauge meter on my cartridge filter as well as in-floor cleaning valve has become foggy and cant read anything.
    is there a way to clean it or can I replace it ?
    Thanks
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    Nov 2010
    Calera, Al
    271
    Re: Gauge meter
    It can be easily replaced, with a new guage and teflon tape... un screw old one and screw in new one with tape on the threads and tighten...
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Jul 2010
    Longwood, FL
    151
    Re: Gauge meter
    Thread on tape. Meaning first put the tape on thread and then tighten ?
    Nov 2010
    Calera, Al
    271
    Re: Gauge meter
    Quote Originally Posted by sunny8088
    Correct, the teflon tape will seal the threads from leaking...
    Apr 2011
    Lynchburg VA
    393
    Re: Gauge meter
    I picked up a replacement gauge at Lowe's for about $7. It was with their pool chemicals.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Re: Gauge meter
    Be careful not to use too much tape. Tape makes the threads thicker, and can crack some fittings if wound in too tight.
    Support the site
