Results 1 to 7 of 7
Thread: Heater removed - Is it junk?
    Aug 2011
    New Jersey
    4
    I pulled out my Jandy Lite2 heater as it was leaking and I'll never use it. Are any parts worth recycling or selling or do I just trash it? Thanks
    30ft x 54in AGP 24,900 gallons
    400 lbs High Rate Sand filter
    2HP, 2 speed pump
    Pool Install April 2012
    22,544
    Re: Heater removed - Is it junk?
    If you know where it's leaking you could put it on Craigslist for parts and get a little out of it.
    Ft Lauderdale, Florida
    1,455
    recycle/scrap yard can get you probabaly $30 in copper and metal. Take the pressure switch and circuit boards off and sell them for whatever you can get for them. That'll buy you a nice dinner.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by Poolsean
    +1
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Aug 2011
    New Jersey
    4
    Sounds like a plan. Thanks!
    2HP, 2 speed pump
    Nov 2010
    Calera, Al
    271
    Quote Originally Posted by spattillo
    Does the control screen still work??? If so i might be interested in buying it. mine works, but the plastic over the screen is damaged so that moisture can get in.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Aug 2011
    New Jersey
    4
    @ROB N - Sorry I missed your post. Yes, the control screen works and it's in good shape. No moisture inside, LCD's all visible, etc. I can take a pic of it today/tomorrow and shoot it to you.
    2HP, 2 speed pump
