Thread: Curved wall
    Curved wall
    I have a curved wall being incorporated into my build. For this do I snip the sidewalls of the track every couple inches to make it flexible? Is there a better solution?
    Jun 2010
    Dripping Springs, TX
    125
    Re: Curved wall
    Can you elaborate a bit more.
    I don't understand what "snip the sidewalls of the track" means.
    Is it just a retaining wall that you are building? How high is it?
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    Re: Curved wall
    I think he means making relief cuts in the track in order to curve it.
    But what type of track? Filling this with concrete or stones or another material?
    Re: Curved wall
    Sorry to be so vague. I am building the outdoor kitchen out of 25 gauge steel studs. There will be 25 gauge steel track on the ground to support the studs. A portion of the outdoor kitchen is curved and I amntrying to determine the best way to construct this portion of the kitchen.
    Re: Curved wall
    Quote Originally Posted by BigT8600
    Correct in making relief cuts. Is this ideal?
    Jan 2011
    Riverside, CA
    352
    Re: Curved wall
    Did you post the same question on the BBQ Source forums?
    There are a couple companies that make flexible track:
    http://www.flexc.com/products.html?topi ... ode=simple
    or this
    http://www.dietrichindustries.com/produ ... rTrack.pdf
    It is much more expensive than cutting a standard track.
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
