Results 1 to 7 of 7
Thread: Where to find pool carboy chlorine valves or pumps
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    Where can i find a dispensor valve or pump for a blue chlorine carboy? Example: Jetline smart spout by allway tools?
    My local pool store claims that they are prohibited to sell the on off dispensing valves anymore. I cannot understand how this is a safety regulation because trying to pour out of a carboy is sure to be messy and unsafe.
    Thanks!
    David
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
    30,432
    Re: Where to find pool carboy chlorine valves or pumps
    I buy my chlorine from a local supplier of pressure cleaning equipment. He has boxes of the valves. I have also seen them online but the only snag will be the shipping on a $4.00 valve.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Are you refering to NAAMCO?
    Nice avatar by the way!
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Mar 2011
    Lower Bucks County,PA
    65
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    I can't find those valves either so I use a plastic squeeze bulb siphon to empty the carboy into several empty Clorox bottles. If you rinse the siphon after each use it'll last a season.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    Thanks Wimpy!
    I ordered two sets (caps and valves) from the link you provided. $9 with shipping.
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    Carboy caps and spigots arrived. Drilled out a 5/8" hole in the center of the cap and screwed in the spigot. I rested the carboy on the concrete and opened up the air hole first followed by the spigot when the spigot overhangs the pool above the deep end return.
    I am looking into installing a liquidator next Spring. I just need to get the ends that will screw into my pump drain plug and heater drain plug.
