Here is a design I came up with that any one can install. Got all the parts from home depot. Will need to cut and glue parts but that is easy. Should not cost any more than $20 including the primer and glue.
Is that 2" threaded couplings on the filter output? I've been thinking of something similar but wasn't sure of the coupler sizes. When I went to Lowe's with one of the non used adapters it seem as though the 2" couplers would screw on about 2 threads and that's all.
That is a threaded 2" coupler. Put on a good amount of Teflon tape and screw it in a good ways. If you have a sand filter there are many threads for it to go on.
