Thread: Would Zinc skimmer weight add metals to pool?
    Apr 2009
    Burlington, ON, Canada
    344
    Would one of these..
    add any metal to the pool water?
    Would I be better off with a rock, or would a rock add something to the water?
    Thanks.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Would Zinc skimmer weight add metals to pool?
    Do NOT use a zinc skimmer basket weight. The zinc will corrode adding zinc ions to the pool. Since it is not electrically connected to any other metal in the pool, it provides NO protection of that metal despite manufacturer claims. If one wants a zinc anode, then one should bury it in moist soil and electrically connect it to the bonding wire to protect all metal exposed to pool water.
    As for a skimmer basket weight, most people just add a pool thermometer that they tie to the skimmer lid for easy removal and to prevent it from getting into the pool. That's what I have and it works great. It's made of chrome, though after quite a few years I have found that it does corrode somewhat (solid stainless steel would have been better than chrome plating). As shown here, some are made of plastic so are unlikely to corrode. This one is chrome and is more like what I have.
    Apr 2009
    344
    Thanks. I've had one of these in the pool since built (the builder put it in). However, I took it out for my recent CUlator test, as I didn't want anything metal in the basket with the CUlator bag. Now I've been hesitant to put it back in - good thing I checked (and you answered). I don't quite get how the thermometer keeps the basket weighted down - is it heavy? In the meantime, do you think a simple rock would be ok..a potato stone like this..?
    Do most people even use something to keep the skimmer basket down? I only ask because prior to the builder supplying me with this (maybe the first two weeks of pool ownership), I came home one day to find the skimmer basket had popped out hard enough to life the skimmer cover off and was laying sideways in the skimmer. When I asked the pool builder about it, he gave me the zinc thingy. Maybe it was a one time chance thing, and I don't even need to weigh down the basket?
    Mar 2007
    San Rafael, CA USA
    12,082
    Most thermometers are heavier than water so weigh the skimmer down. At least my chrome one does for my skimmer basket. Normally the skimmer basket doesn't float as much as you are describing (i.e. not enough to pop off the skimmer cover).
    As for rocks, they are probably OK as they are already weathered and unlikely to dissolve. You can test them by adding some acid to them. If they fizz, then they have too much calcium carbonate in them -- not that this is terrible, but you might as well use something that won't tend to either dissolve nor form scale. If they change significantly in color when acid is added, then don't use them as they probably have too much metal content.
    Jun 2011
    Northeast Ohio USA
    178
    That is a heck of a thing. I would more likely think someone was messing with my pool if I saw that. I do like the idea of putting the thermometer in there, especially when there are kids around that like to play with them until they are broken.
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
